Date/Time: Thu, 02 May 2024 06:40:10 +0000
Reference studies from charts in different chartbook
View Count: 2041
[2018-02-27 05:38:28] |
User106180 - Posts: 88 |
Do you plan to add the ability to reference studies from charts in different chartbooks? For instance, I have chartbooks for each timeframe for the products I am interested in, i.e. 5 minute chartbook, 1 hour chartbook, and 1 day chartbook. It would be useful to reference the Average True Range studies from the 1 day chartbook, for the Daily Range Bands study in the 5 minute chartbook. Currently I have to have 5 minute and 1 day charts (which I hide) in the 5 minute chartbook in order to have Daily Range Bands on the 5 minute charts. Thank you for your help. |
[2018-02-28 03:39:14] |
This is not so easy to do but at some point we will get to this. Check back in a few months.
[2018-06-06 06:15:41] |
Any news on how this is progressing? Thanks
[2018-06-06 07:33:46] |
It is not likely that we would be looking at this until later this year at the soonest.
[2019-04-26 12:28:15] |
User20615 - Posts: 17 |
Hello, any update on this, is it possible to reference study from chart in different chartbook? Thank you. |
[2019-04-26 16:34:21] |
No, this is not supported.
[2019-04-26 18:14:02] |
From previous posts it looks you work on this – does your answer mean you will not bring this functionality in future?
[2019-04-30 16:53:31] |
ILIM KIRGIZ - Posts: 187 |
You can use spreadsheet studies to achieve what you need.
[2019-05-01 02:38:14] |
In response to post #7, not at this time.
[2019-05-01 18:53:51] |
OK, I have one more question – is it possible to access Study summary data via acsil? There is “Include All Chartbooks” option in Study summary, this should solve my problem. Spreadsheet study is unusable in my case, I watch 24 symbols on 6 timeframes, it means I have 24 chartbooks x 6 charts = 144 sheets – this is completely unmanageable… Thank you. |
[2019-09-06 05:50:24] |
Any news on this Sierra Chart at all? Not being able to reference studies in other Chartbooks is not ideal for the Daily Range Bands study (for further details see my original post, #1). Thank you. |
