Date/Time: Mon, 06 May 2024 20:08:42 +0000
Multiple Bitmex Accounts
View Count: 1313
[2018-02-23 02:26:34] |
User342238 - Posts: 44 |
Hi, I'd like to know if it's possible to send the same order, ie a mirror copy, to multiple Bitmex accounts concurrently. Thanks, |
[2018-02-23 03:11:38] |
No, this is not supported.
[2018-05-25 14:07:21] |
User651753 - Posts: 77 |
if you are doing spreadsheet trading could you run the 2nd chartbook with the same study + with a 2nd bitmex DTC account? Will this enable you to trade 2 account? Spreadsheet trading? |
[2018-05-25 18:11:43] |
Not currently the case but this is planned. Although if you use the older BitMex connection method which is no longer documented, you can do this now but we recommend waiting.
