Date/Time: Mon, 20 May 2024 05:07:23 +0000
Chart DOM Settings - default values?
View Count: 1707
[2018-02-22 21:15:53] |
User7817001 - Posts: 96 |
could someone please provide me with the 'default' values Trade > Chart DOM Settings specifically the top two sections Order Types Above/Equal Last Order Types Below/Equal Last Thank you |
Capture.JPG / V - Attached On 2018-02-22 21:15:22 UTC - Size: 90.2 KB - 415 views Attachment Deleted. |
[2018-02-23 03:35:56] |
Here is the documentation for these settings: Global Trade Settings Windows: Chart DOM Settings You need to set them as you require. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-07 08:08:30] |
thanks, I am now 1/2 complete, which enables the trade volume bars on the left side of the window? I tried all the checkbox's and none of them enabled them. Please see attached |
Capture.JPG / V - Attached On 2018-03-07 08:08:13 UTC - Size: 74.15 KB - 349 views |
[2018-03-07 20:21:51] |
We think you are referring to a daily Volume Profile. Refer to the instructions here for this: Chart Trading and the Chart DOM: Daily Volume Profile (Volume by Price) on Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-07 20:22:06
