Date/Time: Mon, 13 May 2024 01:49:54 +0000
Difference between the Apply and OK button
View Count: 1049
[2018-02-20 00:34:37] |
User201774 - Posts: 1 |
When adding my custom study to a chart, I run into this issue: I add my custom study. On the Chart Studies window, I press Apply so that the study appears on the chart. At that point, the study's lines look correct (Before.png picture). After I press OK and the Chart Studies window goes away, it immediately draws extra lines on both the price graph and study starting from the beginning, all the way to where you can see it on the chart (You can see the difference in After.png). I don't want those extra lines. How can I stop them? Date Time Of Last Edit: 2018-02-20 00:34:50
Private File Private File |
[2018-02-20 00:44:44] |
You are putting your attention on the wrong thing. You will have to debug your study and see why this is happening. It has nothing to do with the OK or Apply buttons. There really is little guidance we can give you because we do not know what it is your study is doing to draw those lines. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
