Date/Time: Sun, 12 May 2024 11:38:00 +0000
TPO charts merging a full week or month or some specific time period
View Count: 1028
[2018-02-18 18:04:50] |
User180814 - Posts: 45 |
Hello Sierra, Can you advise on how to merge a full week of TPO days or even a full month or even merge all the days combined to the start of a contract. I would like to be able to see these different views easily without having to merge each day individually. Is that possible. Thanks for your help with this question. |
[2018-02-19 02:27:08] |
Best way to do this is to not use merging and instead set this Input to Weeks or Months: http://www.sierrachart.com/index.php?page=doc/StudiesReference/TimePriceOpportunityCharts.html#Input_ProfileTimePeriodLengthUnit Also refer to this Input: http://www.sierrachart.com/index.php?page=doc/StudiesReference/TimePriceOpportunityCharts.html#Input_NumberOfTPOProfilePeriods We could also update that Input to support from a particular Date-Time to the end. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
