Date/Time: Sat, 18 May 2024 23:41:50 +0000
Static y axis on charts
View Count: 808
[2018-02-17 19:55:00] |
TraderD - Posts: 56 |
Hello, When I scroll along a chart's x axis, the y axis fluctuates and I need it to stay in current horizontal position/price range. The only way I've found to do this is by setting the user defined scale range settings, but that has to be updated frequently when prices expand. Please advise if there is a simpler way to make the current visible price range remain static. Thanks, Darryl Date Time Of Last Edit: 2018-02-20 18:20:27
[2018-02-20 18:20:04] |
The solution in general is to use the Constant Range Scale: Chart Scale and Scale Adjusting: Constant Range (Scale Range) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
