Date/Time: Thu, 02 May 2024 17:07:48 +0000
DRAWSTYLE_TEXT vs DRAWING_TEXT
View Count: 1946
[2018-02-15 14:58:24] |
LenderDevTest - Posts: 15 |
Hi, I need to plot text symbols upper or lower bars. For first I tried to use Subgraphs with DrawStyle = DRAWSTYLE_TEXT, but it's unuseful!!! Because it plots ext with background!!! and it cowers the chart and makes this DrawStyle unuseful. We also can't set FontBold for text plotted by subgraphs. Is there a way to disable filling background for DRAWSTYLE_TEXT DrawStyle? Because of it I have to use custom drawing (UseTool function) to plot text. And if I plot one text symbol on each bar, it cases real performance problems. The chart starts lagging while scrolling. And the indicator starts calculating in counts times longer. The indicator it sierra charts trading terminal work fast. But if we start to use UseTool() the chart and the indicators start to lag. It's a real headache. I think the work with Chart Drawing Tools were made unoptimized. |
[2018-02-16 03:37:04] |
We still need some time to review this. But for the best performance with Chart Drawings set the Horizontal position based on index and not Date-Time: https://www.sierrachart.com/index.php?page=doc/ACSILDrawingTools.html#BeginIndex Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-16 03:38:01
[2018-02-16 03:39:29] |
Hi, I need to plot text symbols upper or lower bars. For first I tried to use Subgraphs with DrawStyle = DRAWSTYLE_TEXT, but it's unuseful!!! Because it plots ext with background!!! and it cowers the chart and makes this DrawStyle unuseful. We also can't set FontBold for text plotted by subgraphs. We will see what we can do in regards to this.
[2018-02-20 17:29:08] |
Thanks a lot! It works much better.
[2018-02-20 17:53:39] |
Yes that is good. We are also working on new Text Draw Styles as well.
[2018-02-20 18:08:58] |
sounds good, The scrolling is good, but the loading time wasn't changed. Count bars: 38504 Loading time(subgraphs only): 3ms Loading time(subgraphs + object DRAWING_TEXT on each bar): 60332ms !!! https://paste.pics/4ea2a3ef31b46195dba53d2fbc4c5e2f |
[2018-03-22 15:48:38] |
User79074 - Posts: 105 |
Sierra, Please make a vertical pixel offset for DRAWSTYLE_TRANSPARENT_CUSTOM_VALUE_AT_Y. I need to stack labels and keep them together if user scales the chart with the mouse.
[2018-03-22 17:11:42] |
This will never happen. It makes no sense whatsoever. The Y value is controllable by the programmer. We have no further comment.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-22 17:11:55
[2018-03-22 19:12:37] |
Why does this not make sense? It makes complete sense. I need to have two subgraphs that use DRAWSTYLE_TRANSPARENT_CUSTOM_VALUE_AT_Y and display stacked labels that can stick together when the user changes the chart scale. Using value only at price does cannot accomplish this.
Date Time Of Last Edit: 2018-03-22 19:18:02
