Date/Time: Mon, 13 May 2024 20:03:40 +0000
data feed amp
View Count: 1018
[2018-02-14 22:08:29] |
User175327 - Posts: 31 |
Hi- I recently opened an account with Amp and am trying to determine the best data feed for reliable bid/ask data. I currently have a Level 5 subscription with Sierra. Should i use the Sierra data feed? Will rythimc work for reliable data? Thx.
[2018-02-15 02:13:51] |
Rithmic will work fine for you. If there any problems you can reevaluate at that time.
