Date/Time: Fri, 10 May 2024 15:24:07 +0000
Volume indicator - different values
View Count: 630
[2018-02-14 19:31:00] |
User58008 - Posts: 32 |
Dear technical support, I have encountered a problem recently and I would like to ask you for help – I am in contact with my friend, fellow trader, and we sometimes share our trades via printscreens, but today I found out that values of my Volume indicator are different from his values. The structure is very similar, but there are 2 candles, that have different values, my value is 2019 and his value is 4019, that is 2 thousand difference. What could cause the problem? I checked my settings, I am running atomic clock, I have 25mbit internet connection. Can this be caused by slower internet connection on my side? Am I having problems with data feed? Thank you for your help. |
[2018-02-14 20:43:26] |
Refer to: Differences With Data and Chart Bars Between Services / Connections / Chart Types And refer to: Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
