Date/Time: Fri, 10 May 2024 14:58:52 +0000
Everyday some of my Spreadsheet studies automatically delete formulas in some cells.
View Count: 656
[2018-02-14 13:06:31] |
User252419 - Posts: 235 |
Everyday some of my Spreadsheet studies automatically delete formulas in some cells and I need to write it again. I have enough space to write formulas as I have Number of Formula Columns set to 35. Thank you |
[2018-02-14 21:00:52] |
The usual reason for this is explained with the Formula Source Sheet Number input description: Spreadsheet Study Inputs: Formula Source Sheet Number Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
