Date/Time: Fri, 10 May 2024 00:26:23 +0000
Description: E-Mini Nifty 50 Symbol: NM View option symbols
View Count: 1210
[2018-02-12 12:54:39] |
User39772 - Posts: 311 |
Hello, on https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Futures#gblx I found the info about Nifty Future mentioned above for Globex. When I try to Find that Symbol I only find for IB: Nifty50 - NSE Nifty SCX How can I load charts of Nifty future with the following exchange enabled: CME with Market Depth for nonprofessional Trading accounts Market Depth Included: Yes Symbols: CME, GBLX If not possible, what do I have to do instead ? |
[2018-02-12 18:26:58] |
This symbol is available with the Sierra Chart Exchange Data Feed but we are not sure what the corresponding symbol is in Interactive Brokers Trader Workstation. Do you know what it is?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-12 18:27:11
[2018-02-12 18:42:14] |
In TWS I can find and trade e.g.: NIFTY Mar12'18 @ SGX |
[2018-02-14 05:07:05] |
But that is not the contract on the CME. However, we think we found it because it was already listed. It is: MNCA-######-GLOBEX-USD-2 It is listed in File >> Find Symbol >> Futures Select the particular contract month you want from the list and you will now receive the real-time data for it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-14 05:07:50
