Date/Time: Thu, 02 May 2024 01:45:03 +0000
using Google Financial Data for historical charts
View Count: 1635
[2018-02-07 07:13:48] |
FFTrader - Posts: 180 |
I am new to using Google Financial Data (I have package 5) for historical data - daily charts, etc. Trying to load, for example, the symbol 0001-HKG ... nothing shows up. I thought to myself it is a learning curve so I better ask someone here. It should be fairly straight forward and yet I could not find a solution. So please point me in the right direction (I have been to and followed the exact instructions on your website already). |
[2018-02-08 22:34:13] |
We do not know the answer to this question. The only thing we can say is the data is just not available from Google assuming the symbol is right. It is stated that this is a service we provide no support for.
[2018-02-11 17:52:02] |
Thanks. What would you recommend for delayed data - non-trading - sources that may actually works with Sierra Chart? Would SC Data Service have more than just Canada and USA delayed data? Say Asia markets?
[2018-02-12 06:01:07] |
You can have a look at the Sierra Chart Historical Data Service which is documented here: Sierra Chart Historical Data Service The supported exchanges are listed on that page. We cannot answer any further questions about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
