Date/Time: Thu, 09 May 2024 11:51:38 +0000
custom alert display question
View Count: 615
[2018-02-05 17:47:08] |
Devil_On_WallStreet - Posts: 67 |
quick question regarding color bar based on alert displaying.... If my alert is based off a mathematic equation... is it at all possible to have it display the actual total of the equation when true. example... say my formula is x+y>=z... could I have it display the value of Z as a custom text?
[2018-02-05 18:37:00] |
Really you will want to use this study instead: Spreadsheet Formula Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-05 20:25:40] |
Thank you!!! BTW in this current market craziness... Tradestation and Ninja have both failed for users in my room... Sierra is holding to this insane amount of volatility SO GOOD!!! Really impressed
