Date/Time: Thu, 09 May 2024 03:10:11 +0000
Reversal bar based on specific price change
View Count: 962
[2018-02-04 22:47:02] |
User807026 - Posts: 86 |
Does SC support a bar mode that is based on a reversal based on a specific price reversal like the original point and figure 3 point reversal bars? It doesn't have to be 3 points but a set specific price change that causes a reversal in price direction.
[2018-02-05 18:45:47] |
Reversal bars are supported and documented here: Chart Settings: Intraday Chart Bar Period >> Bar Period Type >> Reversal Bar (in ticks) (ReversalAmount - MinimumLength) Not sure if that will meet your requirements. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
