Date/Time: Wed, 08 May 2024 11:11:35 +0000
Intra-day Volume indicator
View Count: 1311
[2018-02-02 19:51:17] |
User713273 - Posts: 409 |
I'm currently subscribed tp SC real time data feed. I don't seem to be getting realtime volume updated within the underlying chart. I have to manually delete and download data to receive current and updated volume chart values. Anything I'm doing wrong here? |
[2018-02-02 20:29:41] |
Your Sierra Chart account is not subscribed to the Sierra Chart Exchange Data Feed. Follow the set up instructions here: Sierra Chart Exchange Data Feed: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-02 21:14:09] |
I want to stream up to 500 symbols. I see SC data services offers this service. Is it also necessary for me to purchase quote boosters from IB or does this service cover this?
[2018-02-02 21:41:25] |
The Sierra Chart Exchange Data Feed is completely separate from Interactive Brokers. You just need to subscribe through the Sierra Chart Exchange Data Feed the number of symbols require and this is all.
[2018-02-03 03:20:39] |
Thx. On a seperate note... I have downloaded a separate instance of SC. I have disabled the DTC Protocol Server.I have also listed different Listening Port and Historical Data Port within my 2nd SC instance. I still cannont connect to IB. Please Help. Interactive Brokers | TWS server version: 76 | 2018-02-02 19:13:57 Interactive Brokers | Connected. Waiting for account information. | 2018-02-02 19:13:57 Message from IB: Unable connect as the client id is already in use. Retry with a unique client id. IB Error Code: 326. Request ID: -1. | 2018-02-02 19:13:57 Socket (14) | Socket gracefully closed by remote side. | 2018-02-02 19:13:57 Socket (14) | Received socket Close event. | 2018-02-02 19:13:57 Socket (14) | Initiating close of socket by core. | 2018-02-02 19:13:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-02 19:13:57 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-02 19:13:57 Socket (14) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-02 19:13:57 |
[2018-02-03 05:44:08] |
Refer to substeps 2 and 5 here: https://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php#IBResolvingConnectionIssue This is the relevant message: Message from IB: Unable connect as the client id is already in use. Retry with a unique client id. IB Error Code: 326. Request ID: -1. | 2018-02-02 19:13:57 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-03 05:44:22
[2018-02-05 18:37:39] |
Is there any way to extend the amount of "Instance Client ID" as to add more instances of SC. Thx
[2018-02-05 19:00:01] |
Yes. How many do you need?
[2018-02-05 21:09:23] |
If at all possible maybe closer to 100 would be ideal. Also, can I get pricing for 900 real time symbols.
[2018-02-05 21:24:47] |
So you are saying that you want to use 100 instances of Sierra Chart? This is not a problem, but just surprising. Not sure TWS is going to handle that well. Regarding symbols, we can give you an estimate and that would be $10 per 100 symbols. So it would be another 80 USD per month in addition to the 35 USD/month. And all of that paid to Barchart through us. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-05 21:26:50
[2018-02-05 21:56:38] |
Great on the real time symbols, that is a lot less than IB. More to the multiple instance idea. I will be running 900 charts, I have used "attach trade window to chart" for my attached orders before, the issue is the load it puts on my computer. Our idea was to use multiple instances with around 20 charts per instance and use the Global PnL tool. If I may, I'd like to request that in addition to the global PnL being the collective whole of the charts in the chartbook but also have the ability to attach the global PnL based on chart #. More or less, have the ability to utilize a profit/loss management tool within individual charts. Please let me know if this is doable, it would be of great help. Thanks Date Time Of Last Edit: 2018-02-06 00:12:45
[2018-02-06 02:04:33] |
SPY 10 Min #59 | Reloading chart. | 2018-02-05 18:03:16 SPY 10 Min #60 | Reloading chart. | 2018-02-05 18:03:16 Chart # | Error creating the Trade Window. | 2018-02-05 18:03:18 * SPY 10 Min #61 | Reloading chart. | 2018-02-05 18:03:18 SPY 10 Min #61 | Error creating the Trade Window. | 2018-02-05 18:03:18 * This is the other issue I run into. Limits the amount of trade windows I can create. |
[2018-02-06 02:57:40] |
I have used "attach trade window to chart" for my attached orders before, the issue is the load it puts on my computer. The solution to this is simply after setting the Trade Window controls as you require, then close it. This will save on Windows resources.If I may, I'd like to request that in addition to the global PnL being the collective whole of the charts in the chartbook but also have the ability to attach the global PnL based on chart #. More or less, have the ability to utilize a profit/loss management tool within individual charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-06 03:35:38] |
That is fine. Im still waiting to here back in regards to more Instance Client ID's. Thanks |
[2018-02-06 06:22:15] |
Hi, I just enabled 500 real time symbols and would like to extend the Instance Client ID's for up to 100. Please get back when you have a chance.
[2018-02-06 07:31:59] |
The next release will support 100 client instance IDs, but we think you are going to run into serious trouble on Windows running 100 copies of Sierra Chart. We do not think Windows can handle that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
