Date/Time: Sun, 19 May 2024 23:32:50 +0000
TDAmeritrade (TOS) forex order placement - symbol unknown?
View Count: 1177
[2018-01-27 17:55:55] |
User902003 - Posts: 1 |
When placing a forex chart order to TDAmeritrade (TOS), I receive the following message: "Order Error - TDA order update. Please enter a valid stock symbol" My data connection to TDA seems to be fine. I am wondering if this is just because of the spelling in the order, e.g. "EURUSD", while perhaps TDA is expecting to see "EUR/USD"? Or is there some other explanation? Thanks |
[2018-01-28 04:24:40] |
As explained in the Introduction section here, Forex trading is not supported: https://www.sierrachart.com/index.php?page=doc/AmeriTrade.php#Introduction Only stock trading is supported. We recommend using LMAX or Interactive Brokers instead for Forex trading. Both of these are supported by Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-28 04:24:55
