Date/Time: Fri, 03 May 2024 06:45:58 +0000
OANDA
View Count: 6326
[2019-10-15 17:09:23] |
We looked again at Oanda, but the problem is their technology just simply does not impress us and will cause us difficulties. And it is something that we just cannot move forward with. We did mention the ctrader platform for Forex trading that we might integrate with. We will have a look at that.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-15 17:21:07
[2019-10-18 11:06:02] |
Mack - Posts: 83 |
@Viro Major and @patrick Thanks for pointing out that the swap charges are quite steep. With LMAX I typically get decent fills. Rarely there is a lot of slippage. In your opinion, how does OANDA vs LMAX stack up in terms of spreads, execution, and slippage? Date Time Of Last Edit: 2019-10-18 20:03:54
[2019-10-18 15:51:40] |
We thought with LMAX, your orders are matched with other orders and you should be getting fills against the best available order, assuming your order is a market order.
