Date/Time: Mon, 20 May 2024 01:27:24 +0000
Problem drawing lines in charts
View Count: 1269
[2018-01-26 11:25:06] |
fjgaspar - Posts: 62 |
Hi, I have a problem when drawing lines in a chart. I pick a 5 minutes chart, for example, and I draw a line which goes from one low in a bar to other low in another bar. This line, has several touches of price (I mean, a trend line). Then, if I change the vertical scale, or if the price continues moving and because of the movement Sierra adjust the vertical scale, the trend line moves, in a way that it is not a trend line anymore, because it does not touch the lows. I have even seen the line moving each tic of price movement. It only happens with trend lines. Horizontal lines keep their position whatever the price movement be. Is thera a way to avoid this? If a trend line moves as price moves, become useless. |
[2018-01-26 15:27:32] |
I will post an image to see what I mean. On the left of the image, the lines as I have drawn. At the right, several bars after (few minutes after, it is a tick chart). In the circled area, it can be seen an small shift of the blue line, a little bit more far from the bar than in the left. When you adjust the line to the tick, after a while, it is not in the same place. |
Attachment Deleted. moving.png / V - Attached On 2018-01-26 15:26:54 UTC - Size: 27.87 KB - 305 views |
[2018-01-26 17:57:40] |
Refer to help topic 34 (Lines/Rays or Other Chart Drawings Move After Drawing Them): https://www.sierrachart.com/index.php?page=doc/helpdetails34.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
