Date/Time: Mon, 20 May 2024 01:16:14 +0000
Simulated data feed?
View Count: 1104
[2018-01-25 22:32:06] |
User202045 - Posts: 11 |
Does Sierra Chart offer a simulated data feed similar to the one Ninjatrader provides? The purpose of such a feed is to test whether the setup you've configured (e.g. stops, chase, limits, etc.) works the way you want it to. It just starts with a randomly generated price and generates random price changes or price changes influenced either by a weak or a strong trend. So you can make a simulated trade, then make "price" trend up or down to test whether your targets, stops, and chase parameters work the way you intend them to.
[2018-01-25 22:59:42] |
There really is no need for this and it is not available like this. Sierra Chart offers a massive amount of historical tick data covering stocks, futures, Forex, CFDs. All of which can be replayed at any point in time very easily to accomplish whatever type of testing you require. Refer to: Replaying Charts Data that can be used for testing: Sierra Chart Historical Data Service Sierra Chart Real Time and Historical Forex and CFD Data Service https://www.sierrachart.com/index.php?page=doc/Bitcoin.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-25 22:59:59
