Date/Time: Sun, 19 May 2024 05:23:26 +0000
show market data columns
View Count: 759
[2018-01-24 18:48:56] |
markuz - Posts: 90 |
When applying the "show market data columns" setting through the trade tab on the latest version there are bar charts that cover the data values. is there a setting i can change to adjust this? (picture attached) |
show_market_data_colums.png / V - Attached On 2018-01-24 18:48:38 UTC - Size: 236.32 KB - 348 views |
[2018-01-25 01:13:43] |
You need to uncheck this particular setting: https://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#DisplayVolBarForBidAskSizes Or change the colors. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
