Date/Time: Sun, 19 May 2024 06:51:44 +0000
Tick Chart issue
View Count: 1261
[2018-01-24 14:30:09] |
User536105 - Posts: 36 |
May I ask why the tick chart (I set to 5 ticks) sometimes show 4 ticks or 5 ticks or even 6 ticks within a candle? Thank you.
[2018-01-24 18:08:52] |
Is this with the last bar in the chart? Refer to this page: Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
