Date/Time: Tue, 28 May 2024 07:31:18 +0000
Reward/Risk Properties: Entry, Stop, or Target Horiz Segment Line Width not adjustable?
View Count: 743
[2018-01-24 13:36:06] |
tesseract353 - Posts: 66 |
I would like to make the Marker Type: Horiz Segment, larger than one pixel for the Entry, Stop, and Target. However, the Line Width selection is "greyed out". Is there a way I can change that?
[2018-01-24 18:14:42] |
This is available in the current Pre-Release version of Sierra Chart. Follow these instructions to download the Pre-Release version to get this functionality: Software Download: Fast Update If, for some reason, you do not want to update, there is a workaround in which you can select one of the options that can change the Line Width (such as Plus) and change the line width for this option, then change the Marker Type to Horiz Segment. It will then be drawn with the Line Width that was set previously. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
