Date/Time: Thu, 02 May 2024 09:53:26 +0000
Customizing Colors on the Menu - missing parameters
View Count: 2128
[2013-04-05 06:40:25] |
Rainer - Posts: 108 |
When following the SC Help-Manual, it appears the mentioned colored buttons on the first tab of the Configuration/Properties window Do Not exist and we can not modify any of the predefined 8 custom colors labeled Color#1, Color#2 ... Color#8. Extract from manual={It is possible to customize the colors listed on the menu. Right-click on a chart drawing and select Chart Drawing Properties. Press one of the colored buttons on the first tab of the Configuration/Properties window to open the Color Selector window ...} |
[2013-04-05 07:59:09] |
Refer to the Chart Drawing Tools page again and reload it. We updated it with an image to make this clear.
[2013-04-05 09:23:28] |
Thanks. The wording needs slight alteration as well, as the Define Custom Colors button is grayed out and not used/needed. And the 8 colors referred to are the bottom last 8 colors appearing in a horizontal line.
