Date/Time: Fri, 03 May 2024 07:54:19 +0000
Please extend my trial period
View Count: 1373
[2018-01-23 13:00:25] |
User283129 - Posts: 30 |
Dear all, I kindly ask you if possible to extend my trial period. Did I understand correctly that the trial can be extended for another 15 days? Thank you all for your help. |
[2018-01-23 15:37:12] |
Sierra Chart - Max - Posts: 5599 |
Your account has been activated and the usage time extended if necessary. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends you can request another trial, up to a total of 30 days assuming you have not already received those trial days previously. After this you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support |
[2018-01-26 08:52:31] |
Dear all, Is it possible to add a credit balance with a bank wire transfer? Thanks |
[2018-01-26 09:29:40] |
Yes. Could you start an Account Support Ticket about this here: https://www.sierrachart.com/usercp.php?page=SupportTickets Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
