Date/Time: Fri, 03 May 2024 20:59:24 +0000
SC 1690 prerelease errors changing range bar types on Control Bar Buttons
View Count: 588
[2018-01-22 06:10:59] |
TechTrader - Posts: 116 |
I have several Control Bar Buttons with 'Range Per Bar - Open=Close(in ticks)' Changing the Bar Period Type using the 'Custom Intraday Bar Period Button' to 'Range Per Bar - New Bar on Range Met & Open=Close(in ticks)' results in 'Tick Renko' Reverting to 'Range Per Bar - Open=Close(in ticks)' results in 'Tick Reversal' Typing from the chart ie. 10ro or 10rm works OK. Reverting back to SC 1684 resolves the issue. |
[2018-01-22 07:16:13] |
We will take care of this.
