Date/Time: Sat, 04 May 2024 00:42:27 +0000
[User Discussion] - InfinityAT on Ubuntu 16.04
View Count: 1624
[2018-01-20 13:48:58] |
User102059 - Posts: 2 |
Hi, as the title would like to install infinityAT on Ubuntu 16.04. Sierra is installed without problems but having an account with infinity I can not log in. I tried with many versions of wine but I always receive the usual error that I attach, to see if there are any solutions. Many thanks in advance. wine log file: Error in action RegisterWindowsLibrary child process exited abnormally while executing "exec C:/windows/system32/regsvr32.EXE /s {C:\Program Files (x86)\YesTrader\YesTradeEngineServer.dll}" ("eval" body line 1) invoked from within "eval exec $cmd" (procedure "::InstallJammer::actions::RegisterWindowsLibrary" line 20) invoked from within "::InstallJammer::actions::$component $this" Error in action RegisterWindowsLibrary child process exited abnormally while executing "exec C:/windows/system32/regsvr32.EXE /s {C:\Program Files (x86)\YesTrader\YesTradeEngineServer.dll}" ("eval" body line 1) invoked from within "eval exec $cmd" (procedure "::InstallJammer::actions::RegisterWindowsLibrary" line 20) invoked from within "::InstallJammer::actions::$component $this" while executing "$obj execute" (procedure "::InstallJammer::ExecuteActions" line 62) invoked from within "::InstallJammer::ExecuteActions $id -when $when" (procedure "::InstallJammer::NextCommand" line 8) invoked from within "::InstallJammer::NextCommand .wizard 7707B729-34D5-4648-8703-830473CFE22E" ("uplevel" body line 1) invoked from within "uplevel #0 [string map $map $command]" (procedure "_eval_command" line 22) invoked from within "_eval_command $path $cmd" (procedure "Wizard::next" line 9) invoked from within "Wizard::next .wizard 1" ("eval" body line 1) invoked from within "eval [linsert $args 0 Wizard::$cmd .wizard]" (procedure ".wizard" line 1) invoked from within ".wizard next 1" ("eval" body line 1) invoked from within "eval [list $info(Wizard) next] $args" ("next" arm line 3) invoked from within "switch -- $command { "back" { if {![llength $args]} { set args 1 } eval [list $info(Wizard) back] $args } "next" { if {![llength $args]} { set args 1..." (procedure "::InstallJammer::Wizard" line 13) invoked from within "::InstallJammer::Wizard next 1" (procedure "::InstallJammer::ExecuteActions" line 72) invoked from within "::InstallJammer::ExecuteActions $id -when $when" (procedure "::InstallJammer::RaiseEventHandler" line 79) invoked from within "::InstallJammer::RaiseEventHandler .wizard" (command bound to event) |
[2018-04-02 21:16:05] |
User390510 - Posts: 1 |
any news? Thanks |
[2018-04-02 21:26:04] |
This is not within the scope of Sierra Chart support. It is market is a User Discussion. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
