Date/Time: Sun, 28 Apr 2024 22:50:28 +0000
System Test
View Count: 601
[2018-01-19 12:01:26] |
User39772 - Posts: 311 |
Hello, what is the fastets way to test a System. Currently I use "Replay"-Option with "Accurate Trading System Back Test Mode" which takes hours even with Speed 30. Of course the duration depends on the data history size. Waht is the fastest way available to test a system ? |
[2018-01-19 18:47:24] |
The fastest method is documented here: Auto Trade System Back Testing: How to Achieve the Best Back Test Performance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
