Date/Time: Wed, 08 May 2024 09:40:40 +0000
[Programming Help] - Cycle Tool
View Count: 867
[2018-01-18 18:02:05] |
User00111 - Posts: 111 |
Which library to use to generate a curve on the chart. I would like to modify the internal Cycle Tool as shown in the attached image, adding new parameters. I have the skills to program in C ++ Regards. |
Cycle 1.pdf - Attached On 2018-01-18 17:58:24 UTC - Size: 18.91 KB - 294 views Cycle_Example.pdf - Attached On 2018-01-18 18:00:43 UTC - Size: 132.57 KB - 262 views |
[2018-01-20 02:49:24] |
You cannot modify the Cycle tool in this way. You just need to create your own custom study using ACSIL: Advanced Custom Study Interface and Language (ACSIL) And just use the standard Study Subgraphs and fill in the data that you require. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
