Date/Time: Mon, 06 May 2024 19:14:27 +0000
Spreadsheet studies stop receiving stack/pull data
View Count: 959
[2018-01-18 15:40:01] |
Mistic - Posts: 76 |
I need to get this problem resolved. basically, i leave sierracharts on all the time and on occasion internet goes down in the middle of the night while computer is windows 10 locked. I have 2 spreadsheet studies on my chart using stack/pull DOM data. When i return to desk in morning, dom data since the disconnect/reconnect, is all 0's until the sierrachart screen is looked at. any suggestion as to why dom data goes missing after disconnect?
[2018-01-20 02:52:32] |
Yes we do remember this from before and we did follow-up with a question related to how this problem can be reproduced. How are you doing this?: I have 2 spreadsheet studies on my chart using stack/pull DOM data.
A spreadsheet can use the Depth of Market Data study but cannot access the stacking and pulling data.And in general, from our perspective trying to understand exactly what you are doing and what the problem is really next to impossible. It inherently also makes no sense why it would occur but then again we probably are not understanding it clearly anyway. We would need to get the chartbook and Spreadsheet, and a documented method to reproduce. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-20 02:53:28
[2021-11-22 17:28:03] |
Infinite - Posts: 134 |
Engineering Is there an update to SC possibly giving Spreadsheets access to pulling/stacking data? I realize this is a 3 plus year old thread, thanks in advance |
[2021-11-22 17:36:10] |
You can access pulling/stacking data using the 'Depth of Market Data' Study with Spreadsheets
[2021-11-23 01:22:46] |
@Mistic How many levels are available in that study? |
[2021-11-23 15:01:52] |
You do not have to wait for us to do this. Refer to: ACSIL Programming Concepts: Direct Programmatic Interaction with Spreadsheet Sheets And refer to: ACSIL Programming Concepts: Programmatically Accessing Historical and Current Market Depth Data Develop a custom study to accomplish what you need with Spreadsheets. Do not wait for us. You probably will create something better than we would in regards to something like this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-23 15:02:41
