Date/Time: Sat, 18 May 2024 19:51:35 +0000
Price Scaling settings
View Count: 1268
[2018-01-18 14:20:45] |
markuz - Posts: 90 |
hello, i have my price scale range set to automatic but when the current price moves outside of the current window my charts either compact or scale in a way that isn't readable. i then have to manually adjust the scale and re-center the chart. do you have any suggested setting to avoid this from happening? |
[2018-01-18 15:22:21] |
Not sure why this would happen to begin with. It is not entirely clear what is happening either. The first thing to do is to select Chart >> Reset Scales and do not alter the scale range or position from its default and automatically managed settings by using Interactive Scale Range or Interactive Scale Move. When you notice the problem, provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
