Date/Time: Sat, 12 Jul 2025 00:53:59 +0000
[User Discussion] - crossfrombelow complications
View Count: 1629
[2013-09-22 21:28:10]
toews&kane - Posts: 209
I am working with the crossfrombelow function.
So what happens is the previous cell was 0, the current value is -14 which for me triggers a sell signal, now the value drops to -83.
What I want to do in intrabar is monitor if the value climbs back above -80
how I am doing it is crossfrombelow(O3,-80) but it does not trigger when it crosses that point.
and also I can't use crossfrombelow(O3:O4, -80) because the previous value was 0
Any ideas of how to tackle this problem?
[2013-09-22 23:15:35]
Sawtooth - Posts: 4238
The CROSSFROMBELOW function requires two ranges, and the minimum range is the previous bar. It cannot compare two values in the same bar.
Here's the documentation:
http://www.sierrachart.com/index.php?l=doc/doc_WorksheetFunctions.html#AvailableFunctions
One possible way to tackle the problem would be to add a shorter timeframe chart that uses the CROSSFROMBELOW function, and then use the Study/Price Overlay study to bring it to the longer timeframe chart.
