Date/Time: Sun, 19 May 2024 03:36:27 +0000
Problem with GetStudyExtraArrayFromChartUsingID
View Count: 802
[2018-01-17 07:49:53] |
User563013 - Posts: 11 |
I am using the GetStudyExtraArrayFromChartUsingID, in an ASCIL module. I have a study ID of 1 with 4 subgraphs and I am trying to access the subgraph with an ID of SG2. SCFloatArray Temp; sc.GetStudyExtraArrayFromChartUsingID(sc.ChartNumber, 1, 1, 0, Temp); And I get nothing out of the Temp array, but I can see the data in the chart. After looking at the data in the debugger none of the temp arrays below show data (yes I made sure they wern't being optimized out) SCFloatArray Temp; SCFloatArray Temp1; SCFloatArray Temp2; SCFloatArray Temp3; sc.GetStudyExtraArrayFromChartUsingID(sc.ChartNumber, 1, 0, 0, Temp); sc.GetStudyExtraArrayFromChartUsingID(sc.ChartNumber, 1, 1, 0, Temp1); sc.GetStudyExtraArrayFromChartUsingID(sc.ChartNumber, 1, 2, 0, Temp2); sc.GetStudyExtraArrayFromChartUsingID(sc.ChartNumber, 1, 3, 0, Temp3); How do I access subgraph data with the GetStudyExtraArrayFromChartUsingID? I am following the example. Date Time Of Last Edit: 2018-01-17 07:50:54
[2018-01-17 21:32:02] |
You are using the wrong function. You need to use this function instead: sc.GetStudyArrayUsingID() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
