Date/Time: Sat, 18 May 2024 22:45:24 +0000
Trading:Triggered Limit order Entry
View Count: 861
[2018-01-17 00:20:15] |
User835963 - Posts: 18 |
Hello support, after reviewing so many of your wonderful trading Studies I came across Trading: Triggered Limit Order Entry which I think the closest study to what I'm thinking of. I'm looking for a study has the capability to Place an order on the chart based on a printed signal generated by another Study, let's say Color Bar Based On Alert Condition generated a signal-Arrow or diamond-,is there a way to have the study place a limit or any type of order with Variable offset from the printed Arrow or diamond? thank you guys for everything you do to make Sierra Chart such a great platform. Regards, HS |
[2018-01-17 22:32:24] |
What you need to use in this case is the Spreadsheet System for Trading study: Spreadsheet Systems, Alerts and Automated Trading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
