Date/Time: Sun, 19 May 2024 06:24:34 +0000
[Programming Help] - Welles Wilder
View Count: 1311
[2018-01-16 12:09:09] |
User635423 - Posts: 51 |
How do you code the Welles Wilder Directional Movement System using the Color Bar Based on Alert Condition study? Study used: DMI & ADX & ADXR, ID.3 D+ (SG1) D- (SG2) ADX (sg3) 1ST Buy Signal: D+ is greater than D- and ADX is greater 20 =crosses from below(D+(SG!)>D-(SG2))and (ADX(SG3)>20) 2nd Buy Signal D+ is greater than D- and crosses from below ADX is greater than D- =D+(SG!) >D-(SG2)and crosses from below (ADX is > D-) I keep getting syntax errors. Thanks |
[2018-01-16 13:31:08] |
Xfanman1 - Posts: 320 |
For starters you’re using an ! instead of a “1” in your formula's referencing SG1 unless you just did a typo when you transposed it here?
Date Time Of Last Edit: 2018-01-16 13:44:43
