Date/Time: Sat, 04 May 2024 19:41:36 +0000
[Programming Help] - Trade Activity Log
View Count: 1057
[2018-01-15 13:43:11] |
User840509 - Posts: 4 |
Hi, There is "INV" sign in trade activity log. Can you explain what is that and how I can avoid receiving that sign? Regards, Dima. |
sierra.png / V - Attached On 2018-01-15 13:41:56 UTC - Size: 11.6 KB - 316 views |
[2018-01-16 05:11:32] |
It is the result of invalid price data. Are you using your own price data feed? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-21 16:17:12] |
Hi, Yes, the custom price data feed is used. But how it is possible that all the trades run as expected except of some fields in the log? I am attaching another example. You can see that only some rows of the log show INV values. https://gyazo.com/15b715ac7ba9418f8b670dd15f175703 Regards, Dima. |
