Date/Time: Sun, 28 Apr 2024 19:50:33 +0000
Cryptocurrencies
View Count: 786
[2018-01-15 07:40:50] |
User41512 - Posts: 58 |
Hi, I have my data/trade services set to Cryptocurrencies data- DTC (Data). Cannot find a symbol for Ripple? Thks |
[2018-01-15 20:38:07] |
The symbol for Bitfinex is: XRPUSD-BITFINEX Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-21 09:54:54] |
opci - Posts: 90 |
i can not find the symbol for bitcoin at amp broker rithmic data? what am I doing wrong? thank you
[2018-01-21 11:28:31] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
