Date/Time: Mon, 29 Apr 2024 14:26:57 +0000
Concurrent SaveChartImageToFileExtended calls in multiple charts
View Count: 802
[2018-01-14 21:16:31] |
Usermb - Posts: 126 |
Could it be, that out of multiple concurrent calls to SaveChartImageToFileExtended() at about the same time (o'clock) only one call will be processed, even if the calls happen inside different chart windows part of the same chartbook? If so, is it possible to change this somehow? This is very limiting :-( Both ChartNumber and OutputPathAndFileName parameters have different values for each call: ChartNumber: sc.ChartNumber OutputPathAndFileName: c:\SierraPictures\%ChartName%\%timestamp%.png Width: 0 Height: 0 IncludeOverlays: false Date Time Of Last Edit: 2018-01-14 22:15:06
[2018-01-15 07:01:35] |
This will be solved in the next release.
