Date/Time: Sun, 19 May 2024 00:28:50 +0000
Spreadsheet for Trading - Max Open Position Only Working for Long Positions
View Count: 654
[2018-01-14 02:49:10] |
User104854 - Posts: 441 |
I'm using the spreadsheet study for trading and I'm noticing that the max open position profit (Cell J31) and the max open position loss (Cell J32) are only working when I have an open long position. When I have a short position they do not change and do not adjust as the price changes. They stay at 0 the entire time. Can you check this out please and fix it or let me know if it might be something on my end? Thanks.
[2018-01-14 10:23:26] |
We see this as well. We are checking on this.
[2018-01-14 11:59:30] |
This is now fixed. We are putting out 1690.
[2018-01-16 00:39:48] |
Great. I downloaded Pre-release 1690 and it looks like the max loss works but the max profit still does not. Will there be a current version of 1690 and is this where it will be fixed? Thank you.
[2018-01-16 20:14:21] |
We did additional testing for this now and do not see a problem with either of these Spreadsheet cells on the latest prerelease: Spreadsheet Systems, Alerts and Automated Trading: Maximum Open Position Profit [J31] Spreadsheet Systems, Alerts and Automated Trading: Maximum Open Position Loss [J32] Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-16 20:16:03
