Date/Time: Fri, 03 May 2024 06:27:00 +0000
Date Range on Historical Chart from Bitfinex
View Count: 1107
[2018-01-13 10:02:38] |
Litz - Posts: 131 |
I am having some problems with adding a historical chart (OMGUSD) from bitfinex. The chart is only showing a few days of historical data. When I try to change the Date Range in File (currently showing 2018-01-10) to 2017-01-10 and hit apply the date reverts back to what it was. Days to load is set to 360. Other historical charts work ok ETH BTC LTC but I had those previously up from cryptocurrencies. |
[2018-01-13 19:11:50] |
That is all the data that is available for that particular symbol which we have.
