Date/Time: Sun, 19 May 2024 11:41:34 +0000
VbP on DOM not resetting according to my session times
View Count: 1052
[2018-01-12 23:21:49] |
kinghat - Posts: 120 |
so my problem is that my profile will reset at the start of my evening session time just fine, but when the main start time rolls around it doesnt reset. you can see that it was reset from the evening session in the screenshot below but it doesnt happen in the morning.
2018-01-12_17-18-55.png / V - Attached On 2018-01-12 23:21:17 UTC - Size: 666.61 KB - 361 views |
[2018-01-15 10:15:55] |
This is not currently supported. We are going to add a new Volume Graph Period Type to support this: From Session Start Time to End - Reset at Day Session Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-15 10:58:08
