Date/Time: Mon, 29 Apr 2024 00:16:50 +0000
ATR Indicator - change the color line on a simple condition
View Count: 772
[2018-01-12 19:02:00] |
User44987 - Posts: 3 |
Hi, I would like to change the color line of ATR Indicator based on a simple condition. I specifically need to set, if the resultant value of ATR is greater than for example 3, change the ATR line his color. Does anyone know how to implement this in Sierra? Thanks in advance. |
[2018-01-12 19:28:01] |
Refer to the instructions here for this: Color Bar Based on Alert Condition: Coloring Subgraphs of Other Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
