Date/Time: Sat, 27 Apr 2024 15:43:07 +0000
second install SC error failed to start listening on port 11099
View Count: 1110
[2018-01-12 19:00:35] |
N!co - Posts: 140 |
hi, i installed a second copy of SC and i get this error i think i need to set it to listen to an other port , if so, what port should i use ?? thx DTC Protocol Server failed to start listening on port 11099. | 2018-01-12 18:53:24 * Listening socket (1664). Port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Elk socketadres (protocol/netwerkadres/poort) kan normaal slechts één keer worden gebruikt. | 2018-01-12 18:54:24 * Listening socket (1664). Port 0 | Closed. | 2018-01-12 18:54:24 DTC Protocol Server failed to start listening on port 11099. | 2018-01-12 18:54:24 * |
[2018-01-12 19:28:42] |
Follow the instructions here: Using DTC Server for Data and Trading in Another Sierra Chart Instance: Resolving DTC Protocol Server Port Number Conflicts You need to disable the DTC server. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-07 15:39:40] |
User642139 - Posts: 20 |
I followed the intructions outlined on this page and I still get the same error message. I then deleted the whole folder for the second instance and the error message still remains?! |
[2018-02-07 18:11:13] |
Follow these instructions on your second copy of Sierra Chart: Using DTC Server for Data and Trading in Another Sierra Chart Instance: Resolving DTC Protocol Server Port Number Conflicts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-07 20:08:40] |
This has not resolved the problem.
[2018-02-07 21:51:47] |
This is not making any sense whatsoever. This is point-blank simple. The name of the section linked to is "Resolving DTC Protocol Server Port Number Conflicts". The instructions simply are explaining to disable the DTC server. Document here the steps that you are following, and how you come to conclusion that it does not resolve the problem? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-07 21:53:01
