Date/Time: Sun, 19 May 2024 05:43:43 +0000
Last price of bar changes after refresh
View Count: 805
[2018-01-11 23:41:37] |
onnb - Posts: 661 |
This is a bit hard to explain so hope its clear Summary of issue In replay, when the live bar closes, closing price is 13047.00 - I can see this in the log below and I can see this using the tool value window. I then refresh the chart and the closing price for that same bar changes to 13046.00 This does not happen for all bars. But for some bars, it is very 100% consistent. Log The first row is printed when the bar closes I then pause the replay and refresh the chart The second print is from that Chart: Replay 30X: DYH18 500 Trades #1 | Study: Test Close | Last: 13047.000000 | 2018-01-11 18:33:01 Paused 30X: DYH18 500 Trades #1 | Reloading chart. | 2018-01-11 18:33:38 Chart: Paused 30X: DYH18 500 Trades #1 | Study: Test Close | Last: 13046.000000 | 2018-01-11 18:33:38 Code Used (just for reference) SCSFExport scsf_test_close(SCStudyInterfaceRef sc)
{ SCInputRef str1 = sc.Input[0]; SCInputRef str2 = sc.Input[1]; if (sc.SetDefaults) { sc.GraphName = "Test Close"; sc.StudyDescription = ""; sc.AutoLoop = 1; sc.GraphRegion = 0; sc.FreeDLL = 1; return; } if (sc.Index == sc.ArraySize - 2) { SCString msg; msg.Format("Last: %f", sc.BaseData[SC_LAST][sc.Index]); sc.AddMessageToLog(msg, 0); } } |
[2018-01-14 23:19:37] |
In general we are seeing something like this. We are working on it now. We did get your video by the Account Support Ticket. Probably the exact cause is not what you would think but we will figure it out and resolve. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-15 07:38:53] |
This is now solved. This was simply an issue where when transitioning from the initial load to a replay, one record was being skipped.
[2018-01-15 16:09:23] |
onnb - Posts: 661 |
Great, what version is it solved in?
[2018-01-15 17:25:16] |
It has not yet been released.
