Date/Time: Mon, 29 Apr 2024 14:51:51 +0000
Day range in pips or ticks
View Count: 1081
[2018-01-11 10:17:21] |
grantx - Posts: 244 |
How do I specify the pip or tick count in the chart header since the start of the day (08:00 GMT)? I want to be able to see todays range and yesterdays trading range in the chart header. Not averages. The actual range in ticks. Date Time Of Last Edit: 2018-01-11 18:46:19
[2018-01-11 18:49:05] |
We do see the original post here and we went ahead and put together a study collection for this. We will be adding it to the Additional Files page later: Additional Files (Study Collections, Spreadsheets, Chartbooks) It will be called Daily Range Text Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-11 18:49:39
[2018-01-11 21:24:43] |
John - SC Support - Posts: 31162 |
You can download the Study Collection here: http://www.sierrachart.com/AdditionalFiles/Daily_Range_Text.StdyCollct For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-20 01:12:01] |
Jeff M - Posts: 21 |
This is great! Is there any way that you could include an option to display the Daily Range in Ticks instead of points? Either automatically based on the Futures instrument or a manual selection for a multiplier. i.e. x4 (NQ), x10 (CL), etc. Or is there a way to do this and I am missing it? Thank you |
