Date/Time: Wed, 08 May 2024 16:29:37 +0000
Add option to display only bid or ask volume in Volume By Price Study
View Count: 548
[2018-01-11 09:50:04] |
traderacademie - Posts: 38 |
Hi, I would like to request the option to be able to display in the VbP study: -bid volume -ask volume Study: Volume By Price Settings Input Name: Display Volume in Bars (ln:46) Right now it's only possible to display the difference (bidvolume-askvolume) or vice versa. It makes sense to add the ability to only display the bid or the ask volume as the input "Volume Bar Calculation Method (ln:48)" also allows this. Rgds Will |
[2018-01-11 10:20:01] |
We will add this.
