Date/Time: Fri, 26 Apr 2024 10:43:32 +0000
Notes 30 min candles and TPO 30min periods
View Count: 1477
[2013-09-20 17:28:52] |
trademechanics - Posts: 29 |
I just love the merge odd subperiod for treasuries TPO charts. Now I ask, is there any way to build candlesticks based on this "merge odd period"? The idea is to have the chart setup on the right, where I have two profiles side by side, one showing the volume for the session and the other for the last bar. The problem here is the fact that the 30min candlesticks does not match the TPO 30min periods which creates some reading confusion. Let me do ask another question, what about plot two VbP side by side on the TPO chart, plotting only today's trading day, the same way I have on the candlestick chart? For this to happen the VbP should allow other types of volume graph periods instead of Based on TPO Chart only. Thank you. |
ZN_30min.png / V - Attached On 2013-09-20 17:28:46 UTC - Size: 108.28 KB - 503 views |
[2013-09-22 20:07:33] |
For the first question, the answer is no and it is not planned. Let me do ask another question, what about plot two VbP side by side on the TPO chart, plotting only today's trading day, the same way I have on the candlestick chart? This is planned for later on. When we can get to it.Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
