Date/Time: Wed, 01 May 2024 22:49:21 +0000
Real time Cumulative Delta bars...
View Count: 830
[2018-01-10 17:32:51] |
User629089 - Posts: 93 |
Hi, For the study "Cumulative Delta Bars," under Subgraphs, when you check the Value Label you get a reading for the Cumulative Delta but it only updates on a bars close, for example on a 1 minute. I'm not seeing any way for this to update in real time instead of once per minute on the bars close. Is there a way for this study to update in real time? Thanks... |
[2018-01-10 17:45:18] |
Make sure you set the Value Label for the Close (SG4) Subgraph and not the Open Subgraph
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-10 17:45:47
