Date/Time: Thu, 02 May 2024 11:21:01 +0000
Show Order Fills On Chart
View Count: 6281
[2018-01-10 15:29:51] |
007700 - Posts: 43 |
Is there a way to add/remove text like price/position in the order fill line on the chart....? Sample "S(Lmt)6650.25(Open)5"----------- Sample "S lmt 5"-------------- |
[2018-01-10 19:10:02] |
To the extent they can be customized, that is explained here: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-11 03:02:34] |
Attached is a pic of a sample of what im looking to achieve I see how to change the colors but nothing to remove text |
SC Order Position.jpg / V - Attached On 2018-01-11 02:59:45 UTC - Size: 88.66 KB - 1075 views |
[2018-01-11 18:36:09] |
OK we thought originally that is what you were referring to but you made mention of order fills so that is why we gave you the order fill related documentation. Refer to step 6 in this particular section here: Chart Trading and the Chart DOM: Viewing Orders and Trade Position on the Chart / Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-11 22:12:26] |
Thanks I got it now this is what i was looking for The working order lines lines on a Trade DOM can be set to display less detail so they are more compact and take less horizontal width. This allows you to resize the Trade DOM window and reduce its overall width and still be able to see the order lines. To reduce the amount of detail on order lines, uncheck the following option Global Settings >>Chart Trade Settings >> Working Orders >> Display Detailed Order Information. |
