Date/Time: Thu, 02 May 2024 17:14:43 +0000
With ACSIL, how to get the ID of a study using the name of the study
View Count: 1759
[2013-09-20 16:26:15] |
SoundsLikeSun - Posts: 30 |
Hi, I use a lot the function sc.GetStudyArrayUsingID. However, I keep on adding and retrieving new studies, and it is time consuming to verify the IDs and update all the progs. Therefore, is it possible to detect a study ID through its Short Name ? It would very useful, as the shortname rarely changes. Thank you for your help, Thomas |
[2013-09-20 17:00:41] |
This is not supported and it is not planned. It is not considered a technically correct, efficient or reliable method to get the study ID this way. What you need to use is a study Input that lists studies and select the study that way. Refer to the example here: http://www.sierrachart.com/index.php?l=doc/doc_ACSIL_Members_Functions.html#scGetStudyArrayUsingID Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-09-20 17:56:40] |
Ok, Thank you for the fast answer |
