Date/Time: Sun, 05 May 2024 08:09:46 +0000
P/L Line disappearing again
View Count: 1296
[2013-09-20 16:16:59] |
User36492 - Posts: 48 |
Hello, For the past two or three weeks, I've experienced a repeat of the problem reported in this thread: P/L line disappears It began after recent updates to Sierra. I use Interactive Brokers & IQFEED. I have an Advisor account, but I'm not using that feature in Sierra. I just select the proper account on the trade box. |
[2013-09-20 16:41:32] |
Check to see that there is a position for the selected account in Trade >> Trade Orders and Positions >> Positions. The positions on that tab come directly from Trader Workstation. If it is not shown for the account you have selected or it is not correct , then you need to use the Order Fill calculated position instead: https://www.sierrachart.com/index.php?l=doc/doc_TradeStatusWindows.html#OrderFillCalculatedPosition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-20 16:42:20
